Author Topic: Toroid Winder w/o cutting the wire.  (Read 4284 times)
Online Psi
Re: Toroid Winder w/o cutting the wire.
« Reply #25 on: May 28, 2019, 06:24:57 am »
Guys do we have good videos on how they works? I managed to find only the ones that are used for big torids! what about the smaller ones used in PC motherboard, they have the diameter of under 1.5cm
I think they are the same, just smaller.
Although, the tiny motherboard DCDC toroids usually only have like 5 turns.
So they maybe done with hand machine, since china labour is cheap
Thinking about it some more, with thick wire and only a few turns there maybe other automated options for motherboard DCDC inductors
The wire will hold its shape, so it could be pre-bent into a spiral by machine and then rotated onto the toroid core.
« Last Edit: May 28, 2019, 06:35:15 am by Psi »
Offline ali_asadzadeh
« Reply #26 on: May 28, 2019, 10:52:48 am »
Thanks, I tough they might have use different method, since they are small, and most of them use multiple parallel thick wires!
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
