DESIGN APPROACH
The Model 3440A Digital Volt
meter uses a voltage-to-time-interval
conversion system as outlined in
Fig. 3. The time interval is evalu
ated by digital counter techniques
to obtain the digital display.
The unknown voltage, appropri
ately attenuated, is applied to a
comparator to which a linearly-de
creasing ramp is also applied. When
the ramp voltage becomes equal to
the unknown voltage, a coincidence
pulse is generated, as shown by the
timing diagram in Fig. 5. The ramp
voltage is also applied to a zero
reference comparator which has sig
nal ground for its other input.
Again, when the ramp voltage be
comes equal to signal ground, a
coincidence pulse is generated by
this comparator. The time differ
ence between these two pulses is a
direct analog of the difference be
tween the unknown signal voltage
and signal ground.
The time difference is converted
to digital form by the counting of
clock pulses. The first-occurring
comparator coincidence pulse opens
a count gate, enabling the counters
to operate, and the second pulse
closes the gate to terminate the
count. The first comparator pulse
also starts a Colpitts oscillator
which provides the clock pulses.
By appropriate choice of ramp
slope (400 v/sec) and clock pulse
repetition rate (400 kc) the total
count displayed corresponds to in
put millivolts. Range switching
operates an input attenuator and
places the decimal point so that the
display reads directly in volts.
Source:
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1963-11.pdf p.3
