Author Topic: Solved? - Hall effect probe for superconducting magnets  (Read 648 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: August 01, 2020, 01:19:02 pm »
Hi all!
I've been given a gaussmeter from my uni, a 70's vintage Systron Donner 3101.
A probe came along with it, but the probe is clearly from a different instrument, since it has a vastly different connector.
I'd like to try and get the probe tested before messing with the huge rack instrument.
Here is what is known:
 - It's a flat ceramic chip hall effect device on the end of a probe, model and manufacturer has been too smudged to read. Probe is potted.
 - The connector reveals 3 pairs of leads and a shield. I believe the pairs to be coaxial with individual shield:
Connector pin wire colors:
       - White + Black
       - Red + Black
       - Green + Black
       - Cable shield
       -None of the black wires are connected to each other or to main cable shield.
A hall effect device needs a current between two ports, and a voltage differential is extracted via two others:
Since a pin is lacking for that, it stands to reason the current supply might be using its shield (black wire?) as return,
and the two remaining colored wires are V+ and V-
How will I go about testing this? What voltages/currents are usually used with naked Hall effect devices? Keep in mind, I believe modern Hall effect devices already has a regulator and current reference built in.
Thanks in advance!
« Last Edit: August 01, 2020, 07:43:44 pm by ChristofferB »
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
    • My channel:
Re: Figuring out a hall effect probe for superconducting magnets
« Reply #1 on: August 01, 2020, 06:53:12 pm »
Ok so I've stripped the probe element, and it seems 6 wires lead to it. There is a small black nodule at the silicone strain relief right by the sensor which could be a thermistor, as a hall device really only should need 4 wires. I'm considering breaking these out to some headers for easier access, but it still doesnt solve the issue of pinout...
Is there any semiconductor junctions in a hall device that can be checked with a diode checker?
    • My channel:
« Reply #2 on: August 01, 2020, 07:21:23 pm »
2 of the leads are almost certainly an NTC - at room temp. They have a resistance between them of 1.8K, when freezed with a freeze spray it shoots up over 10K.  (white+black pair)
Makes sense for a probe for a cryogenic magnet! That leaves only the 4 wires that would be expected!
    • My channel:
« Reply #3 on: August 01, 2020, 07:38:52 pm »
Okay, almost got it figured out!
Applying +5V through an 1K resistor to the green+black pair gives a voltage between 0 and 1 mV out on the red/black pair when a powerful neodymium magnet is brought near.
I still have no idea what voltages/currents is expected for a device like this, although I think sensitivity is set with the bias current.
