Tbh, that didnt csme to my mind, yes would have been Vetter to do it that way.
Oh my Bad, i corrected that in the current schematic, there ofc connected directly.
Now im Sure i'll get the LPF to Work, Just the weird Mosfets behavior left.
Edit: Nope, C22 isnt the fault. Somehow the 7,5V are shorting the Signal out. When i connect R19/20 directly to R22, the Signal is completely gone. I dont get it, thats the Same with the other 2 LPF of the midrange, and its working fine there.
It must be the OP amp, bc in this Case the 7,5 arent Busses with the audio Signal. Maybe i'll Change the verry First Input high Pass to the 33hz, then Connect R19/20 directly to R22 and removed the 7,5V from R22, then it should Work.
