Author Topic: power supply  (Read 1766 times)
Offline Arlen moultonTopic starter
  • awesomeness in radios
power supply
« on: November 18, 2014, 06:46:42 pm »
I have a small Nokia 5volt transformer is there anything simple yet awesome I can do with it that doesn't envolve blowing it up?
Offline Seekonk
Re: power supply
« Reply #1 on: November 18, 2014, 08:38:39 pm »
You could power that one transistor amp.  It is what it is.  If you bust it apart it probably has a zener in series with an opto isolator to control voltage.  Replace that with a TL431 and it could be adjustable from about 4 to 12V.  For those into solar, many of these electronic  wall warts will work down to 50V (at reduced current) and provide an isolated source for a micro.
Offline Paul Price
Re: power supply
« Reply #2 on: November 18, 2014, 11:38:49 pm »
It could be just a transformer, a simple non-switcher power supply as was first used with Nokia older cellphones.
In this case, it would be just a small power transformer with rectifier diodes and a large valued filter capacitor, no regulation.
If it is a wallwart type heavy, it's just using a transformer, otherwise it is a switchmode power supply.
What it is good for is to supply a low-power around 3-5V /400mA circuit, and whether what it powers is something awesome or mundane is up to you to find.
« Last Edit: November 18, 2014, 11:46:14 pm by Paul Price »
