Author Topic: PerkinElmer Thermopile Module...  (Read 551 times)
Offline unmanagedTopic starter
« on: May 11, 2020, 07:16:32 pm »
I have a Perkin Elmer Thermopile module I can't figure out how to convert it's output to a temperature reading... All that is listed is the voltage swing of 0.25 volts and I am not sure how that equates to a reading at all. I have attached a few data sheets and photos of this device.... its a pull from a device. Trying to make a thermometer.... I looks like PE is now Excelitas I called and was asked to send photos but not holding my breath to hear back from them as I am not a OEM...
73
KE4TVV
Gavin G
Unmanaged
Re: PerkinElmer Thermopile Module...
« Reply #1 on: May 11, 2020, 08:01:45 pm »
OK so I am guessing the voltage swing is 0.25 from lowest possible  reading to 4.75 volts for highest but without the specs on this module i cant figure it out without guessing ...
Offline Kleinstein
« Reply #2 on: May 11, 2020, 08:05:39 pm »
It is a little odd that there is no more info on  how to convert the voltage to temperature.  Chances are the the 0.25 - Vdd-0.25 V range corresponds to the specified temperature range. So 250 mV for -20 C and 4.75 V for the maximum.
 If in doubt just compare to a normal thermometer.
