Author Topic: Phantom current - where's it going?  (Read 824 times)
Offline angust_ukTopic starter
« on: September 27, 2019, 07:18:05 am »
Hi all
I'm struggling to figure out where I'm losing ~11mA in the very simple design below - it's an STM32F103 and a TLC5947 LED driver (driving 24 white LEDs). The design will be battery powered, so in standby I am putting the STM32 into sleep mode (which I've checked works ok with current consumption reducing as it should), and switching the driver's VCC off with a P-channel MOSFET. However even in this state I'm seeing 11mA into VCC and I can't figure out where it's going!
I have noticed that when off, the MOSFET's drain is at 1.5V (around half of VCC), so I guess I'm seeing leakage from somewhere else, but I can't figure out where!
Any ideas appreciated!
(post edited as apparently I managed to forget the schematic!)
« Last Edit: September 27, 2019, 07:42:38 am by angust_uk »
Online Siwastaja
Re: Phantom current - where's it going?
« Reply #1 on: September 27, 2019, 07:22:39 am »
Assuming Vcc=3V, 33mW dissipated in a small spot on a PCB should cause small but well noticeable heating, which you should be able to see using, for example, a cheap IR no-contact thermometer. In similar cases, I remember seeing heating of around 1-2 degC over the surroundings.
Put it on a table, let it run for 15-20 minutes without touching it anywhere and measure.
The following users thanked this post: angust_uk
Offline jhpadjustable
  • Salt 'n' pepper beard
« Reply #2 on: September 27, 2019, 07:51:15 am »
Wild guess, but are you disabling output drive on the STM's SPI pins when going to sleep?
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
« Reply #3 on: September 27, 2019, 08:00:14 am »
Ok, it looks like the issue may well be my lack of understanding of the STM's various sleep modes! After more poking around at the registers I've put it into a deeper sleep mode which reduces consumption to around 1mA. I'm not using an external 32kHz crystal which I guess may limit my ability to go much lower, but for the moment this is significantly better at least!
Many thanks jhpadjustable and Siwastaja for the pointers!
