Author Topic: Identify this Surface Mount Component  (Read 909 times)
Offline RofflesaurTopic starter
« on: September 26, 2019, 04:59:02 am »
On today's episode of Name this Component:
What the heck is this?
843010-0
I'm troubleshooting an RF receiver for an automotive RF keyless entry module. While checking various components on the board, I came across that. It looked like a fuse, so I tested continuity and there was none. It's so far on the back of the board and nowhere near where power enters, so what would a fuse be doing there? It appears to have the number 4.0 on it, and the area of the PCB where it sat was labeled "X1." Here's a pic of that...
843014-1
Edit: This board is from 1997, so it may not be something that's used in modern designs.
« Last Edit: September 26, 2019, 05:06:21 am by Rofflesaur »
Offline Mark
Re: Identify this Surface Mount Component
« Reply #1 on: September 26, 2019, 05:07:53 am »
Xtal
« Reply #2 on: September 26, 2019, 05:17:31 am »
Xtal
In a glass MELF package? Is that a thing? Lol.
Offline DaJMasta
    • medpants.com
« Reply #3 on: September 26, 2019, 05:38:36 am »
Looks like it is, X is a crystal designation and it's got the load caps on either terminal, so I'd assume it's a 4MHz crystal.
« Reply #4 on: September 26, 2019, 05:53:41 am »
I think you guys are correct. I didn't even know such a thing existed! I connected it back to the vehicle and probed the component with my DVM (don't have a portable scope). I very briefly saw 3.98Mhz before it crashed from the additional loading. I suppose I'll post in the RF sub forum tomorrow, as this is out of my area of expertise. Thanks.
Offline TimNJ
« Reply #5 on: September 27, 2019, 02:59:59 am »
« Last Edit: September 27, 2019, 03:01:35 am by TimNJ »
