Poll
How about creating a GitHub repository for this?
Not really interested
7 (70%)
Would like to take a peek at one
2 (20%)
Would like to use the concept, but mostly create stuff myself
1 (10%)
Would like to duplicate the modules as they are
0 (0%)
Total Members Voted: 10
Author Topic: Playable electronic modules - modules in action  (Read 9053 times)
Offline HendriXMLTopic starter
    • KiCad-BOM-reporter
Re: Playable electronic modules - debouncing switches
« Reply #75 on: March 13, 2019, 12:22:16 pm »
Did some testing with the SN74HC14 on a breadboard.
Going to the ON state is delayed by 15 ms, going to the OFF state with some 25 ms.
I did same rapid pushes on the button to see if everything was registered, and it was.
So for human/kid interaction this is fast enough. For automated systems it might depend, but in that case better switches and the proposed latching method might be a good idea. My pushbuttons are probably of the worst kind: leaving the speed of closing/opening the switch up to the user. Better switches will be of the click/clack kind. Where some tension is build up and then released going into a different state much faster (like the toggle switch). Also better contact materials (gold) will give better results, but were on a budget :)
« Last Edit: March 13, 2019, 12:35:40 pm by HendriXML »
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Re: Playable electronic modules - modules in action
« Reply #76 on: March 16, 2019, 02:56:22 pm »
Two of the new revision modules are ready!
« Reply #77 on: March 16, 2019, 03:01:11 pm »
Surface mounting the IC's "my way", takes to much time so, I'll will order some of these. It makes the modules 50% more expensive, but I think it will be well worth it.
