I have a design I'm working on that consists of two PCBs that are separated by 8 inches or so. The main board has a microcontroller, battery charger IC, and other stuff on it. The other board just has a few LEDs, momentary switches, and a slide switch for power. I've got the main power running from the main board to the daughter board, thru the switch, and then back to the main board. I'd like to not run main power to this daughter board, but I'd like to keep the power switch on the daughter board. Is there a way to use a transistor on the main board that is controlled by the slide switch on the daughter board to turn on and off main power? Ideally I'd prefer to run as little power to the daughter board as possible as I'm concerned about EMI. I just don't have much experience with transistors as switches.
