Hi to a tube amp designer:
I'm in the construction stage of building a low power ( 5W ) stereo amp, and I want
the phono preamp to be one 6021 tube per channel. I imagined it would look like the
one in the RCA manual that uses 12AX7. The B+ will be about 150V. I guess the plate
resistors would be on the low side, and I would like battery or led bias ( maybe 1.2V ).
I need an entire schematic, but certainly the RIAA compensation resistor & capacitor
values. I think they would be close to what a 12AT7 would use, but how close is
close enough? Any direct help or a shove in the right direction is appreciated. Thank you
