Well, yes, in general ESR won't be the 120Hz value.
I suppose they might be leading you to an answer of iteratively solving for (or approximating) f_test ~= f_underdamped, or perhaps substituting them to get a closed form solution but that may be messy.
Note that a single frequency, steady state measure -- which is how we measure ESR -- isn't the most meaningful for a pulse, as the pulse contains quite a broad range of frequencies. A more complicated equivalent circuit may be desirable.
In general, the ESL + ESR + C model can be further decomposed into many parallel and series RLC elements, modeling its real impedance more accurately over a wider range of frequencies. This assumes one has an impedance plot for the component, of course; this is rarely given for electrolytics, unfortunately.
In practice, electrolytics' characteristics vary enough (between individuals, and over temperature and time) that such accuracy really isn't important. The pulse might deliver 2200A one day and 1900 the next (say if the following day were cooler, or the capacitor were switched out for another).
