Author Topic: MC34063 and transformer question  (Read 3298 times)
Offline TrickyNekroTopic starter
  • Country: gr
  • Drinking Frappé on the way to Isomnia!
    • Youtube channel, electronics and more ;-)
« on: November 04, 2013, 04:31:59 pm »
Hallo again people,
I am trying to build a step up dc/dc converter for my project using the MC34063 part. In my project I need two power rails.
I need a ground referenced 15+ V rail and a floating 15+V rail. The rails will be used to power 12V regulators, which in turn
will be used to power gate drivers for MOSFETs. Instead of having two separate topologies, I thought it would be much more
practical to use one. So, instead of an inductor, I thought that it would be nice to use a transformer, with the primary as the
step up inductor and the secondary for the isolated rail. I need the output transformer output rails to be over 15V after
rectification so that I am sure that the regulators work properly, I don´t really need a precision circuit.
Since the MC34063 works with a comparator, it will be skipping pulses. The problem with that is that the voltage on the isolated
side, might and probably will, drop, something that I really don´t want. So I thought that if the non-isolated side has more load
than the isolated side, it will probably work. The question is... Is my thought correct? If not, want should I do?
From some research, I found that LM25017 would be great for producing both an isolated and non-isolated rail, BUT it´s a step
down converter, with that being said, it´s pretty much useless, since I´ll be powering my system will 12V and I need more than 15V
at the output, and I really don´t want more circuitly (something like a step-up to make my originally 12V rail 24V volts for it to work).
Still, while reading through the datasheet, I understood that this concept can work.
And then my question about the transformer. I got some samples from Coilcraft for the transformers. The provide with the DCR value
and the maximum power rating. I dug a little bit around the site of Coilcraft and found in their F.A.Q. that the Irms can be found from
this formula: Power rating = Irms² x DCR. Am I right about this? I mean that I got some JA4650-BL. They have a power rating of 2W
and a DCR of ~0.122 Ohm. That means that the Irms = ~4A, right? I just want to be sure that the transformer is good for the task.
I don´t think that I will be drawing more than an average of 150mA - 200mA per rail.
Anyhow, these are my questions. I hope that I was able to clarify them as good as I can, but if in need of more details, I´ll be around  8)
Thanks for your time and patience, in advance!
Best Regards, Lefteris
Greece
If you are an engineer and you are not tired...
You are doing it wrong!
Offline Bored@Work
Re: MC34063 and transformer question
« Reply #1 on: November 04, 2013, 08:51:42 pm »
Stabilize the unregulated output with a bigger cap, establish a minimum load on the regulated output.
In general I would suggest to use e a symmetric design. I.e. flyback topology with two separate secondary windings, one regulated.
  • Country: gr
« Reply #2 on: November 05, 2013, 01:18:02 pm »
I can do the later. I have two windings for the primary and two for the secondary. I can use the primary windings in series and then
use each seperate winding for each supply. But still again I run into the problem that I need a higher power source. In that configuration
I can use the MAX5075.
Anyhow, I will draw the two possible schematics and upload them, so that people can understand easier what I want exactly. Plus I will
try the circuit with the MC34063 tonight and I will upload my results. :-)
I hope that it will work, probably it will. The funny thing is that I just calculated the current needs of each rail and if I am correct the average
current shouldn´t be more than 20mA per rail, which gives me also other opportunities but still I want to try this one. I just want to get away
from bootstrap. When you deal with until 15V supplies bootstrap is a nice method but when you want to go over than, you don´t get to have
many solutions.
This project serves more educational purposes but I could end up with a very good H-bridge design... so yeah :-P
If it is good at the end, I will make it open hardware ;-)
Thanks for your post,
Greece
