Author Topic: DS1052E - Wave recording RCD file  (Read 8636 times)
Offline migsantiagoTopic starter
    • MigSantiago's Web Site
« on: October 25, 2010, 08:03:38 pm »
Hey guys
I was testing the Record Mode on my Rigol and saved a .rcd file on my USB memory.
To record a wave...
Utility, Record, Mode Record, Operate.
Then to save it to your USB memory...
Mode Storage, Location External, Save.
Now I have the file, how can I read it using my PC? I am attaching it to this message.
The file contents are not in plain TXT.
Thanks!
Offline scrat
Re: DS1052E - Wave recording RCD file
« Reply #1 on: October 25, 2010, 10:04:20 pm »
RCD format seems to be from the old series, DS1000E saves into WFM format, isn't it?
For this last format there are some readers, and at RC groups someone tells about a reader for old scopes' files.
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
« Reply #2 on: October 25, 2010, 10:56:05 pm »
Yes, it can also save a screen in a WFM file, but it's only a screenshot.
The RCD file seems to save more time, not only a printscreen.
Offline PeterG
« Reply #3 on: October 27, 2010, 02:10:23 am »
The rcd file is only 8k in size. the wfm files seem to be 16k in size and contains 16k of data.
Maybe the rcd file is compressed?
I know the wfm files are not compressed and can be read easily with a good hex editor.
I have attached a wfm file captured from a DS1102E showing the cal signal from the dso.
Regards
« Last Edit: October 27, 2010, 02:14:16 am by Darkman1969 »
Testing one two three...
« Reply #4 on: October 27, 2010, 02:40:16 am »
Well, it could be a 8k sample file, 8 bits per sample. I don't remember how many 1ms samples I took.
Tomorrow I will run another test.
Offline marianoapp
« Reply #5 on: October 27, 2010, 03:24:42 am »
the rcd file stores a series of frames of the signal at a parametrized interval, much like a video. To save the raw data you have to choose the WFM format in the Acquire menu, and then save to an internal or external location
Offline PeterG
« Reply #6 on: October 27, 2010, 03:47:20 am »
migsantiago, could you post a rcd file with the dso connected to its cal output?
Thanks.
« Reply #7 on: October 27, 2010, 02:21:37 pm »
Thanks.
Sure, the RCD file recorded 40 frames.
The current voltage and timing selections are shown in the BMP file.
« Reply #8 on: November 06, 2010, 02:02:06 pm »
Hi
I'm still interested in this solution, if you have info please let me know. Thanks.
Offline PeterG
« Reply #9 on: November 07, 2010, 01:00:30 am »
Migsantiago, i cant seem to find anything that will open this file. The Rigol Scope software wont open it, maybe this file type is from an older generation. Have you considered updating the firmware on the scope? Newer firmware may allow you to save as a WFM file.
Regards
« Reply #10 on: November 07, 2010, 03:08:15 pm »
Regards
Hi man.
I've always been able to save as a WFM file, no problem with that.
I just wanted to test this RCD file and see if there was more info from it than from a WFM file.
