Nothing you can do will alter the power in >= power out balance, Watts are Watts.
Yeah, I thought of that right after I posted above... even using the switching modules directly from the main power supply, I could never go more than available.
dumb question: can I use a linear transformer with DC instead of AC? I could only find examples of transformers used in AC and I have not much knowledge about.
Also, do you have any good links about PSFB power supplies? I could understand the basic functioning from a few web pages, but I'd like to know more. However, at this point I'm more interested in using those simple buck converter modules since it requires less knowledge and sounds easier to put together.
