Ahhh, I see the difference looking at the LTC4267-3 datasheet and dn361. So should I cut the trace from the negative end of C5 to VPortN and tie it to PGND?
Is this an issue with dn361 then?
BTW Jay_Diddy_B, I met you at dayton hamvention last year.
I had that HP electron load that you swapped that 6632A for. Thanks for that! I has really come in handy lately with some power supply stuff I have been doing. I did a few of the standard mods to it (quieter fan, binding posts on the front, cleaned it out, etc) and it has been awesome.
Are you going to be at hamvention this year again? It is a bit early, but I figured I would ask!
