So I actually have one of these squirreled away and dug it out for another look.
(I found it on Ebay and not only does it have the repair stamp I used to use, the S/N makes me actually wonder if it was that very same unit where I blew the brake resistor after finishing an overhaul!)
I take it that one needed to let the unit stabilize for a few seconds before starting the turntable?
Anyway, I opened up the unit to see the exact part number on the 4081 and it is a MC14081BCP.
I shoulda mentioned the optos and the fact the PWM board had +170V DC on it.
I did go back and check KiCAD, it has IGBT symbols and I went and updated Q3, Q4, and Q7 accordingly.
I still remember the final testing process for these - the controller was set to drive the turntable at 200 RPM (during which we calibrated the trimpot on the Logic to get it within +/- 2 RPM), then checking it at 300, 400, 999, and finally 1499 RPM, then let it coast to a stop (I presume this is where the brake board comes in), then a check of the 20 RPM maintenance mode.
I THINK, but I cannot be sure, that the redesigned PWM board had different sized gate resistors, but the rest of the circuitry was unchanged from the old design - the brake daughterboard circuitry was even incorporated into the PWM board (and for some reason, they went with a 4-layer PCB as well).
If I remember right, the date on the schematics was from the very early 1980s (and this was a slightly redesigned version, so I guess the original design was from 1980 or so).
Also, looking at the Logic, I got the frequency wrong (it wasn't written on the schematic I transcribed) - it is actually 3.58MHz.
No plans to do anything with the unit or design - mainly keeping it around for nostalgia.
