If your goal is a clock you can read from across the room, then I think your design priorities are wrong, in that you’ve allocated tons of space to unimportant elements, at the expense of the most important elements of all, the time digits.
Even if you keep the seconds the same size, at least shrink the massive colons and AM/PM indicators. Your digits are very narrow, and spaced a bit close to each other, so the digits are going to be hard to read. Meanwhile the colons, which don’t actually carry any information, are gigantic and widely spaced from the digits, and the large AM/PM indicator (which is of only secondary importance since it’s usually obvious from context which one it is), all take up valuable space.
Furthermore, the way you scaled your digits means the vertical segments are far thinner than the horizontal ones. Again, reducing readability. (And it doesn’t look nice.)
