Author Topic: Looking for a DC motor bridge IC 2A+ and a 80-100V buck converter IC @30W  (Read 1206 times)
Offline YansiTopic starter
  • STM32, STM8, AVR, 8051
Hello
/RANT_BEGIN/ second attempt to post a messsage in here. The first one got lost due to pissfuly short session timeouts here. I was so angry that I have destroyed my mouse, slaming it into ground. /RANT_END/
For optimizing and redesign of already existing research equipment made from discretes and a few ICs so far, I am searching for some parts for an upgrade, especialy these two:
A DC motor bridge IC. 16V operation, 2A continual load.  Ideally anything "dumb" without smart functions, like TLE5206. SMT package needed (But please no QFN, as the project manager doesn't like them - don't asky why  ;D ). The TLE5206 is precisely what I need, but the TLE has got idiotic pricing and not so good availability though. Do you know any other similar product, that I could use? I think there must be a fuckton of these ICs, but probably I do my googling somehow wrong.
It doesn't need to be precisely a DC motor bridge, it won't be used for a DC motor though  ;)
A buck converter IC. 60V input voltage nominal, so something which will hold up to 80 or better 100V input. I need 16V output at 2 to 3 amps. I think this will be the hard one. I have found only a few of these like LM5007, but this is only a weak current. So external switch is not a problem - only if there is such IC that supports it. Also SMT package required here. Do you know any such IC usable for that kind of PSU?
Thank you a lot!
Yan
//PS: Destroying the old mouse was fun, I already needed a new one - was a good stress relief  ;D
« Last Edit: September 10, 2015, 07:51:05 pm by Yansi »
