Author Topic: Power supply ground  (Read 1072 times)
Offline t_rynerTopic starter
Power supply ground
« on: March 08, 2017, 05:48:05 pm »
Hello! This is my first post here, and I just finished prototyping a audio amplifier on a breadboard. I plan on powering it with a power supply module I salvaged out of an old DVD player(I checked the power module's outputs with a meter). However on a previous audio amp, I had a problem with it not being grounded properly. I noticed that on most commercial power supplies, the ground planes are split internally, but are linked via a pair of optocouplers. Why is this? why not just bypass the optos and connect to a earth pin?  ??? ( with a simular but smaller power module, it used a chasis ground to the metal case. when connected to power and earthed to the outlet, there was a sudden and violent release of magic smoke   :-BROKE ) Why is this?
Offline Zom-B
Re: Power supply ground
« Reply #1 on: March 08, 2017, 06:32:35 pm »
  • Allow multiple power supplies to be put in series (create balanced +/- voltages)
  • Inject voltage in the middle of a circuit that's already grounded
The following users thanked this post: t_ryner
Offline Codebird
« Reply #2 on: March 08, 2017, 06:43:13 pm »
As above, plus:
 - Ground loops and common-mode noise when two such devices are used together. Creates the annoying hum and puts out a ton of unwanted RF.
