Author Topic: Pillar drill motor control  (Read 695 times)
Offline cleanworkbenchTopic starter
« on: August 24, 2019, 07:39:50 am »
I,m looking into the idea of changing out the original single phase motor on my pillar drill to something controllable in variable speed. What type of controllable motor should i be looking at for this application.
Thanks
Offline MosherIV
Re: Pillar drill motor control
« Reply #1 on: August 24, 2019, 08:00:55 am »
Why? Is it broken?
Does the pillar drill have a set of different size pullies and belt inside?
http://pillardrillmachine.weebly.com/the-pillar-drill.html
The pullies and belt are there to allow you to change speed/torque.
I doubt you will be able to easily replace the single phase AC motor for a DC varible speed one.
I do not think anybody makes DC motors in that power range.
I am not awear of any single phase AC motor inverters, as far as I know you can only get 3 phase motor inverters.
Offline mzzj
« Reply #2 on: August 24, 2019, 08:32:28 am »
Thanks
Depends a lot on your drill size but I replaced the orginal weakling and POS belt drive in my drill press with 1.5kW 1500rpm 3-phase AC motor and VFD.
Belt set to 1:2 speed reduction gives enough torque to drill 25mm holes or tap M16 to steel and max spindle speed of 2200rpm when VFD set to 150hz
Offline mikerj
« Reply #3 on: August 24, 2019, 11:07:54 am »
As mzzy says, the way forward for variable speed machine toos is a 3 phase motor and a variable frequency drive (VFD).  Small VFDs are now quite inexpensive and a suitable motor should be easy enough to find.
