I have seen HV PSUs built with a 6550 tube, far more powerful than a 6AQ5.
The 0A2 regulator tubes have a really nice glow, hope that you can find them. Last time I checked they were in short supply...but you can always go to Akihabara.
EDIT: There is a note on the schematic: SD1 and SD2 are shown in reverse polarity. Mount opposite way.
The way I see it, the diodes are oriented correctly, they are generating a negative voltage for V4's grid. Anyone has a different opinion?
I'll take a look at those 6550 tubes, I'll check to see what they are worth over here.
It's funny, some common tubes in the States or more often in Europe are hard to get here, but others are super easy. Bit of pot luck sometimes, but substitutes can almost always be found.
I'm about to go on holiday, so it'll be a few weeks before I can make another trip to Akihabara or heat up a soldering iron...
I managed to get myself two 0A2 tubes for $15 the other day, so I'm all set there.
(See the attached pic)
And yep, I saw that note re. the diodes.
I'm redrawing the schematic and I got that detail.
I'd be interested in what others think about their orientation too.
If your transformer is rated for 200mA, this means that the *rectified* current you can draw is about 60% of that. The reason is that
- the rectified current is not sinusoidal, but comes in shorter, high amplitude pulses
- the pulses are not in phase with the voltage.
so the magnetizing effect is very different from a resistive load and that puts more stress on the magnetics.
Result: your 200mA transformer makes a good 100mA PSU with some safety margin.
Recommended literature: Horowitz and Hill Art of Electronics CH. 9
Ah-ha, makes perfect sense. I'll dust off my copy of AoE and take a closer look.
Look at me, doing all this learnin'
