A bit of my history building a simple tube regulator for a theremin (fixed 250 V output).
I used a triode-connected 6Y6GA as the pass tube (low voltage drop) with a 6SH7 pentode error amplifier and a 0A3 75 V reference. The first build had a high frequency (roughly 70 MHz) parasitic oscillation, which I cured with a stopper resistor between the 6SH7 plate and the 6Y6 grid. Thereafter, I was paranoid about oscillation, and looked carefully at the output. The 120 Hz ripple was acceptable, but I found a similar amplitude line-synchronous component at precisely 10 Hz. I futzed around with the circuit near the 6SH7 plate, but only the amplitude changed—the frequency remained 10 Hz. While I was going crazy, my wife suggested that maybe I was picking up something, rather than an oscillation. I disagreed, since the only two things powered on were the oscilloscope and the soldering iron. Shutting the iron off removed the 10 Hz signal. The soldering station and DUT were both connected to the bench outlet. Apparently, the servoed soldering station at idle, with a zero-crossing switch, was in a limit cycle at 10 Hz, synced to the 60 Hz line. This must have modulated the heater of the 6SH7 and put a 10 Hz component into its input offset. A dual triode diff amp would have had less response to this heater variation.
