Author Topic: Please help identify connector  (Read 1050 times)
Offline NivagSwerdnaTopic starter
« on: June 06, 2019, 08:30:49 am »
I am rejigging a vintage  Stag PP40 programmer
It would be really useful if I could source a male equivalent to this connector
Any ideas what it is called?
Thanks
Offline johnkenyon
Re: Please help identify connector
« Reply #1 on: June 06, 2019, 09:16:56 am »
96 or 64 way DIN 41612/IEC 60603-2 connector
Note that you should check which rows are actually populated with pins - the connector shell looks like 96 way, but if the middle row is empty you only need a 64 pin "a+c" connector.
The following users thanked this post: NivagSwerdna
« Reply #2 on: June 06, 2019, 10:11:22 am »
Thanks.  I think only the outers are populated... so a+c
The connector isn't straight but has in/outdents... is that something special?
Offline PA0PBZ
« Reply #3 on: June 06, 2019, 10:52:58 am »
It's a keying system: https://www.fclane.com/sites/default/files/din_41612_part_numbering_information.pdf
Offline johnkenyon
« Reply #4 on: June 06, 2019, 01:30:24 pm »
Looking at https://b2b.harting.com/files/livebooks/en/PRD0200000100063/downloads/livebook.pdf
The slots on the bottom and top are for coding keys. You have to slide one or more coding keys into the socket to make it a coded connector. No keys inserted=not coded.
(page 23 of 238).
The notch on the sides might be of more interest - I would use the above document to check out further.
Offline ArthurDent
« Reply #5 on: June 06, 2019, 02:08:07 pm »
Here's a variation of this type of connector I have on a piece of Telco equipment. All I needed to connect was two power leads and two outputs so I installed my own commonly used connectors rather that try to find the mate for this one.
