Hello all,
my circuit has 2 entry points for esd.
I've filtered properly (at least, I guess since it's working) with a TVS the entry point #1 - a push button - but I can't find a solution for the entry point #2, that is an on/off key switch that drives the positive rail.
Without a proper clamping on the entry point #2 all the other protections are useless since the pulse goes thru all the positive rail.
Of course here I can't use the TVS+RESISTANCE+CAPACITOR, because with the series resistance I have a lot of voltage drop and current limiting.
Can you suggest me a possible solution?
A low pass filter could be enough? I think I need to clamp most of the energy to ground and to use the filter only for the remaining pulse.
Any thought is appreciated!
