Can you install wireshark ?
When you start it up it will ask what adapter to capture.
On the right side uncheck everything except the wired checkbox.
Then select your main adapter (probably the top one)
and type in the filter line
port 67 or port 68then hit the enter key (or double tap on the line you selected before)
Reset the adapter and you will get probably 4 line in your wireshark window.
If you click on the line with "DHCP ACK" and in the bottom screen click open the
Dynamic Host Configuration Protocol (ACK) part then you see a line with
Your (client) IP address: xxx.xxx.xxx.xxxThis will be the IP address of the adapter.
If not can you save the captured data and post it here (you probably need to zip it)
Benno
