Hi guys,
Quick update here:
All the parts are in, including the switch that was back ordered(it came early!).
Now I am just waiting for the pcbs that should come shortly.
All that has shown interest in this thread has gotten a message thru the forum, not all have responded, but there is no rush(but if you have signed up in the thread and not gotten a reply, check your inbox.).
Kean is the first from Australia to sign up, I have replied to your DM.
And you are more than welcome to do a run your self, the more devices gets built, the happier I am
IanJ has gotten his adapter(one of the prototypes) and I am happy to report that it worked fine with wingpib with default prologix config.
He pointed out that connection details is missing from the github repro, I will write a guide on there as it is not totally clear that one should just use standard Prologix details as I avoided name dropping as much as possible.
I have done some quick testing on the test controller software, but not been able to make it work(with any type of adapter, mine or others), I will look into this to figure out whats going on, I am sure the fault is on my side.
I also have on my list to fix fixed IP support and the first post of this thread to make it easier to read, just been a bit busy here.
So far 19 out of a run of 40 units is spoken for, plenty to go around still
And of course, the units will be available after they are built as well, until I run out, for any one needing one in the future.
Thanks again for all the support, I will do my very best to deliver these as quickly as possible.
