Author Topic: POE IEEE 802.3af pad spacing  (Read 436 times)
Offline Samuel KälinTopic starter
« on: October 24, 2019, 12:16:39 pm »
Hi everyone,
I don't use forums very often, so please bear with me.  :)
I am designing a Arduino-compatible ESP32-based POE as a hobby project. It is an isolated power design that should fit the IEEE 802.3af standard.
The first Prototype is already here and working (mostly  :P ).
For the second Version I decided to switch the POE-Ethernet jack to a low-profile variant, so that Arduino-Shields actually fit onto it.
The best one I found is https://www.digikey.ch/product-detail/de/w-rth-elektronik/7498210220A/732-10843-ND/6598165 (Datasheet: https://katalog.we-online.de/pbs/datasheet/7498210220A.pdf).
In the datasheet it states that it is IEEE 802.3af compliant.
Now my problem:
The data- and the power-pads are incredibly close together. Wouldn't that lead to a lower than 1500V rms isolation if I lead the data-lines to the other side of the isolation-zone? Do I need to add a Signal-Transformer despite already having one integrated into the Ethernet-Jack?
Does anyone have any experience with the required pad-spacing?
I appreciate every answer, thanks  ;D
Samuel
