Hi Guys,
I need to be able to regulate a source down from 18-20 volts to 15 volts, at 2 amps. I have several LM7815CV (15V) regulators; however, the datasheet says they can only source up to 1.2A. I have tried placing two of these in parallel, but one of the IC's does more of the work than the other. Just for fun, I have also tried placing three LM7805 (5V) regulators in series, but still the last one gets too hot for comfort.
Is there a way that I can evenly share the power dissipation among 2+ regulators? I only have small heat syncs available, so ideally I would like to split it over 3 or 4 of these to keep the heat density down. I'd appreciate any ideas.
