Author Topic: Transformer half wave rectifier inbalance in voltage  (Read 1444 times)
Offline ZeTeXTopic starter
  • Country: il
  • When in doubt, add more flux.
« on: June 18, 2016, 11:23:27 am »
Hi  :)
I have the following schematic on breadboard:
Where V1 is 230/12V 3VA transformer, that outputs 15VAC RMS no load.
C1/C2 are vishay 470uF 50V caps.
D1/D2 are just jellybean diodes
The issue I'm having is that the voltage is not equal on the caps, for the positive cap (C1) I measure about 20V no load and with 240ohm load I measure about 14V, and for the negative cap (C2) I'm measuring about 7.50V no load and with 240ohm load I measure about 6V~.
Why is it so?
Online PA0PBZ
Re: Transformer half wave rectifier inbalance in voltage
« Reply #1 on: June 18, 2016, 11:34:46 am »
Swap the diodes.
Does the problem move?
Yes -> bad diode.
No  -> bad cap.
  • Country: il
« Reply #2 on: June 18, 2016, 11:46:19 am »
Swap the diodes.
Yes -> bad diode.
No  -> bad cap.
Fixed! Bad diodes.
thanks!
Offline Audioguru
« Reply #3 on: June 18, 2016, 02:49:07 pm »
The extremely high unlimited inrush current blew up the little low power diodes. Why not use rectifier diodes made to do what you are doing? 1N4001.
  • Country: il
« Reply #4 on: June 18, 2016, 03:42:20 pm »
I'm using 1N4007 anyways, I might have shorted out something that killed the diodes, but it fixed now anyways.
