Author Topic: Need a fast industrial output driver IC, high-side mosfet.  (Read 865 times)
Offline LeicesterTopic starter
« on: November 29, 2018, 09:43:25 am »
Hi everyone!
I'm designing a rotary encoder for a CNC spindle. My sensor outputs A/B/Ref in differential signals which I process into TTL. For the output I need a high-side switch that can switch 24v at very fast speeds (<10uS)... Currently on my prototype there is a ITS41K0S-ME-N which is way too slow, have not thought about that when I initialy designed the circuit. I use this "smart" thingy because it is protected against practically everything.
Do you know anything similar but much faster? I'm struggling...
Thanks for any help!
/Leic
Offline Benta
Re: Need a fast industrial output driver IC, high-side mosfet.
« Reply #1 on: November 29, 2018, 01:04:11 pm »
You'll probably have to build it yourself.
All the "smart" high-side switches I know are pretty slow.
Offline jfiresto
« Reply #2 on: November 29, 2018, 02:24:02 pm »
Almost all intelligent, automotive/industrial high side switches that need few external parts, such as the ITS41K0S you considered, have output delay times on the order of 100 µs – at least, as of a few years ago, when I looked.
If you can find room for a few more passives, the Infineon (International Rectifier) AUIPS7221RTRL is a couple orders of magnitude faster. Mouser is the first distributor I could find that currently has them in stock.
« Last Edit: November 29, 2018, 02:49:31 pm by jfiresto »
-John
Online SiliconWizard
« Reply #3 on: November 29, 2018, 02:41:36 pm »
