Well, it's pretty well identified on the can - the problem is I can't find anything on line about it (like pinouts, working voltage etc).
I acquired 5 100 Mhz crystal oscillators - 14 pin dip form factor but only pins in the 1, 7, 8 and 14 positions. The printing on the can is Cardinal LM 1400E 100 MHz. Tried the obvious (pin 1 as o/c or en/dis able, pin 7 as ground, pin 8 as output and pin 14 as VCC - 3.3 volts initial guess). Can't see any output but draws about 400 mA which seems very high. Since the current drain seemed high I haven't tried 5 volts or higher.
I found the Cardinal website but could find nothing about LM 1400E on there. Any ideas?
Rob
