Author Topic: Reverse Voltage Protection for Development Board  (Read 12988 times)
Offline Luis EstradaTopic starter
Re: Reverse Voltage Protection for Development Board
« Reply #25 on: February 28, 2021, 02:38:21 am »
That's a KiCAD thing, I didn't even notice it lol! But yea, I see it is kind of an overkill, I just wanted to learn more about circuit protection as new EET grad.
Offline gnuarm
  • Country: pr
« Reply #26 on: February 28, 2021, 04:26:21 am »
Nothing wrong with that.  Part of the protection problem is there are so many solutions, so many it is hard to know when to use what.
A design I'm involved with is using a $4 chip and four FETs to select between two power sources.  Yeah, a bit of overkill.  The guy designing it never saw a Linear Technology part he didn't like.  The parts are good, but not cheap.  He had a $3 input protection chip and two FETs to protect against over and reverse voltage, when a diode would do pretty much the same job (everything being "protected" already had nearly as high a voltage rating).   He is also using a $4 switching regulator when a $0.50 part would do the job.  Why?  He says he knows "the LT part will work" as if the other regulators don't.  Whatever...
« Last Edit: February 28, 2021, 06:22:36 am by gnuarm »
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
The following users thanked this post: Luis Estrada
« Reply #27 on: February 28, 2021, 04:32:27 am »
Yeah I understand, this project is not so critical. It's just a Development board for a PIC18F45K50 mcu, which works at max 5.1 V so I wanted to make sure it didn't get damaged. I did some calculations and the Diode will do fine.
Offline Terry Bites
« Reply #28 on: February 28, 2021, 01:36:28 pm »
I use 64 bit Microcap11. It would use 12 but it keeps crashing on win10 pro.
https://www.spectrum-soft.com/download/download.shtm
