You need to look at the datasheets, see what sort of accuracy/error range it has. One current sensor I looked at is 1% accuracy, at 100A that means it's limited to 1A steps.
For your example, I think 20A is the nearest size for Current Sensors anyway, so 200mA. See what you can find that is 0.5% or better (lower) accuracy.
