Author Topic: Power over DVI connector?  (Read 7196 times)
Offline MamybopoTopic starter
« on: April 20, 2018, 05:56:18 pm »
I found this old 7" 800x640 touchscreen panel from a Konica business printer. It has a DVI-D connector, but that is the only connector on it. No power!
The DVI standard has 5V 50mA on pin 14, which seems much too little to drive even a small TFT screen.
Inside the device, there's a switching PSU board with a 125V 1.5A fuse, among other things.
I'm afraid to plug this monitor to my graphics card to test, because I suspect that Konica simply used the DVI connector because it was a cheap and available 24 pin cable.
What is the easiest way to determine if it is safe to connect this to a regular DVI output and perhaps supply 5V externally?
Offline iwtommo
Re: Power over DVI connector?
« Reply #1 on: April 20, 2018, 06:34:08 pm »
Follow the traces from the fuse to wherever they go?
Surely a dvi connector doesnt send 125v at 1.5a
Offline Yansi
« Reply #2 on: April 20, 2018, 07:42:44 pm »
The DVI connector on this display is nowhere close to a DVI signal standard, as far as I remember forum thread from some years back.
DO NOT plug to the PC graphics card!
« Reply #3 on: April 21, 2018, 05:11:56 pm »
Was that an eevblog forum thread?
Offline Yansi
« Reply #4 on: April 22, 2018, 09:28:35 am »
I am not sure, unfortunately. But I recall well a discussion about a display panel from a printer, with a DVI connector, that was nowhere near the DVI connector.
But that should be absolutely clear to anyone, who knows a bit about DVI, that you can't supply a 7" LCD panel from the integrated 5V DDC power, and that there is no way in hell to manage a touch screen with it.
Just open the sucker, I recall that there was also Texas Instruments flatlink receiver chip, like a SN65LVDS86A. (So no TMDS signalling either, good old LVDS instead).
Should be easy enough to interface, if you work out the connector pinout.
