Author Topic: Power supply design: 60V, 30A  (Read 17901 times)
Offline CentmoTopic starter
« on: October 28, 2013, 11:52:21 pm »
Hello, I'm an EE but a little out of element with power supply design, so I'm looking for some suggestions.
I need to charge a 14S LiPo as fast as possible from a standard 120V/20A wall plug. A fully charged pack is 4.2V * 14 = 58.8V. With the AC circuit able to supply up to 20A at 120Vrms (2400W), I figure that a DC supply could reasonably provide 30A at 60V from this circuit. Please assume that the battery pack can safely handle this charge current. The output voltage must be variable in the range 0-60V, so that I can implement a control loop to perform constant-current charging.
Ignoring the cell-balancing part of the problem (this will be done externally from the DC supply), where can I begin to design such a DC supply? I know it may have to be bulky, but the lighter, the better. Is there a development kit I can start from?
Thanks.
Offline KJDS
    • my website holding page
Re: Power supply design: 60V, 30A
« Reply #1 on: October 29, 2013, 12:16:33 am »
If you just need a few, then buy an off the shelf supply.
If you need a lot, get a custom design from one of many power supply manufacturers. Even if you just need a few then putting a few pounds their way is likely to be the cheapest way forwards.
If you really need to design it in house, hire in a contractor.
If you have a few years and a lot of spare money then start reading about switch mode supplies. If you don't mind it being huge and heavy then a linear solution could be used. I know it's fun to design new things, but I don't see it as a sensible engineering solution unless there's a real commercial need to do so.
http://www.eltek.com/wip4/
Are just one of many that could provide a solution.
Offline jabramo
« Reply #2 on: October 29, 2013, 01:24:18 am »
Why don't you just buy an application specific device??
Will something like this not satisfy your needs?
http://www.thunderpowerrc.com/Chargers_2/TP1430C
I guess you still need a power supply which would cost an extra $100 on top.
This route is way safer and easier than building one from scratch. Also power electronics are not cheap. You'll need to source a high power transformer and a bunch of power transistors. You'll most likely have to design custom pcbs because there's no way you can breadboard a project like this. Thermal management will come into play no doubt which calls for heat sinking.
This project would be a pretty big undertaking even for someone experienced in power supply design. Unless your looking to put together something really crude I'd recommend ponying up for the application specific gear. And I wouldn't recommend something crude for something as explosive as lipos (I've seen youtube videos of 3S cells exploding into a ball of fire and I can't imaging what a 14S battery would look like). Lipos are no doubt extremely dangerous when mishandled, do the right thing and buy gear that was specifically designed to handle them.
EDIT: Being an EE yourself I think you will agree that keeping yourself and more importantly the people around you safe is the number 1 priority.
« Last Edit: October 29, 2013, 01:34:16 am by jabramo »
Offline digsys
    • DIGSYS
« Reply #3 on: October 29, 2013, 01:33:10 am »
.. or pick up a couple of these - www.measureshop.co.za/buy/manson-hcs-3604-bench-power-supply-0-60v-0-15a-price-includes-vat-317729
They have analogue control inputs for V/I/on. I have a few and they work FINE. All you need then is a simple analogue controller / monitor.
Offline jabramo
« Reply #4 on: October 29, 2013, 01:43:33 am »
Even that can be dangerous.
From my limited battery knowledge LIPOs are extremely sensitive and volatile. Charging all 14 cells without balancing can be disastrous.
Offline ee.jmlp
« Reply #5 on: October 29, 2013, 01:43:47 am »
Thanks.
Get a cheap welder inverter with DC out and constant current control. Wrap some loops from low voltage secondary until you get a max of 60V with 30A.
Happy hacking ;)
« Last Edit: October 29, 2013, 03:41:13 am by ee.jmlp »
Yeah buddy!
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: October 29, 2013, 02:24:51 am »
A 48V telecom supply would work nicely. Or 4 modified PC PSUs in series.
« Reply #7 on: October 29, 2013, 04:30:39 am »
Thanks for all the replies.
The charger is required for a commercial product, not just a single hobby unit for myself, so a hacked solution won't do. I have searched far and wide for existing products which might fit the bill, but they have all fallen short.  The ThunderPower 1430 unit mentioned by jabrano looks great from the description, but it turns out that it maxes out at 10A when you charge 14S (to the shagrin of some irked customers who only found this out after finding an addendum stuffed into the user manual).
http://rc.runryder.com/helicopter/rr/rrpv.htm?ID=681276&PG=1&IN=1
I am currently using four iChargers configured for 7S charge in 2S2P configuration to achieve 30A charging of the 14S pack. These require two large 24V DC supplies, so in total we are talking six individual components - not practical to ship with a commercial product. What I need is a single integrated solution.
Regarding the cell balancing, I have that taken care of on a separate board connected to the battery. It will not allow any of the cells to exceed 4.200V. So, all I need is a single 0-60V, 30A power supply which I can control (set output voltage) remotely with my MCU (via SPI, or otherwise). (Thanks for the tip on the 15A unit, digsys - do you know of a 30A version?)
Since I am only charging batteries, there is no stringent requirement to have low output ripple. I think this is what makes bench-top DC power supplies so expensive, and I'd prefer not to have to shell out $1000 for such a DC supply. But...I may have to. I am realizing that I don't have a year or two to design and build my own.
Offline AmmoJammo
« Reply #8 on: October 29, 2013, 05:28:06 am »
It simply can't work properly!
At the very least, you would need to monitor the voltage of all 14 cells (independently), and have the charger shut down when just one cell got to 4.20volts, or you risk overcharging and damaging that cell.
Of course, seeing you wouldn't be balance charging, you'd need to balance the pack every 5 or 10 charges, to make sure the cells are still balanced, or you risk over discharging one of the cells, and damaging it...
The only way I can see a "dumb" charger being used to quickly, and safely charge a 14 cell Lipo pack, is to charge each cell separately, with its own 4.2volt, isolated, current limited supply....
A fixed voltage supply charging all cells in series simply can't work! If it was for a home setup, and didn't really matter so much if you stuffed your own batteries, then go for it! But if its for a commercial product, you need to rethink the idea ;)
Offline AG6QR
    • AG6QR Blog
« Reply #9 on: October 29, 2013, 05:39:15 am »
A 20 amp 120V branch circuit normally shouldn't have a continuous load of more than 80% of its capacity, or 16 amps.  In order to produce 60V at 30A from 120V at 16A, your converter is going to need to be about 94% efficient.
I'm not surprised you're having trouble finding a commercial product that meets that requirement.
I don't have a suggestion other than to figure out where you might relax the requirement.  More input power?  Less output power?
Offline pinkysbrein
« Reply #10 on: October 29, 2013, 06:04:06 am »
How are those balamced chargers usually constructed? One flyback based charger per cell?
Offline AmmoJammo
« Reply #11 on: October 29, 2013, 06:30:30 am »
As far as I'm aware, they charge the cells in series, but monitor and discharge the cells that are charged more than the others ;)
Which means the whole process is rather slow, as you're charging all the cells, while discharing the higher charged ones  :-DD
Offline pinkysbrein
« Reply #12 on: October 29, 2013, 11:05:10 am »
Hmm why not just temporarily take the higher voltage ones out of the string? Needs a non trivial of electronics per cell, but you could keep charging.
« Last Edit: October 29, 2013, 02:42:42 pm by pinkysbrein »
Offline Strada916
« Reply #13 on: October 29, 2013, 11:25:49 am »
break the battery pack down to manageable cell count, like 4,4,4,2 Never seen 14s packs. Big electric helis are the only models I have seen with anything close like 12s but they break them up into smaller more manageable packs for charging and storage.
The Bone, the Off-White, the Ivory or the Beige?
Offline ConKbot
« Reply #14 on: October 29, 2013, 12:14:15 pm »
While its good to see people not encouraging being reckless with lithium batteries , battery cell balancing should be done by the BMS and not by the charger.  Hobbyists need high performance, eek out every last miliohm (how many planes have you seen with a fuse? ;) )  and low cost, so they omit the balancer in the pack and just use a balance charger, and just call a low pack voltage cut off good enough on discharge.
Power tool batteries, laptop batteries, none of these break out individual cell taps because cell balancing (in power tool packs) or cell monitoring (in laptop packs, no balancing, just matched cells) is internal.   Since the thread starter is talking about a pack which charges at 30A I'll assume its at least 10AH, and has a short circuit current in excess of 100A. Having no BMS on such a battery would be fool-hearty at best, and quite concerning
Not only that your mains can vary something like +15%to -10% or there abouts. Most NA PSU's have an input range of 100-138Vrms. Then there is the fact that a lot of older houses only have 15A branches not 20A. So the most you can guarentee out of a NA residential branch is 100Vrms x 15Arms = 1500VA. You would need PFC in order to get anywhere near that as well then conversion efficency etc. You could run it off the 240Vrms line that would half the input current requirment.
If this is a consumer product and it needs a 60V 30A charger for the Li-Po inside, I think I want it, doesnt matter what it actually is  >:D
Offline Crazy Ape
« Reply #15 on: October 29, 2013, 12:37:15 pm »
This thread over at candlepower should be required reading if you're messing with lithium based cells.
KABOOOOM!
http://www.candlepowerforums.com/vb/showthread.php?262234-TK-Monster-Explosion
« Reply #16 on: October 29, 2013, 02:53:18 pm »
Regarding cell balancing, the cell balancing is being taken care of by a separate board, at the battery itself. Each individual cell voltage is being monitored to a 1mV accuracy by an AFE and MCU. As with any lithium charger, when any one cell gets close to 4.200V, charging will change from constant-current mode to constant-voltage mode so as to avoid an over-voltage condition (MCU will control charger remotely). When the highest voltage cell actually reaches 4.200V, it will be bypassed with a FET and power dissipating resistor in series. The FET will be switched on/off with some hysteresis to maintain 4.200V across the cell, until the rest of the cells catch up. This stage of the charging process is rather slow, compared to the constant-current charging stage, which will pump out the full 30A.
AG6QR, you brought up a good point that UL dictates I cannot exceed 80% of the branch circuit rating. 120V*20A*0.8 = 1920W. Assuming 90% efficiency, 1920W * 0.9 =  1728W. 1728W/60V = 28.8A. So, I may need to relax my 30A requirement to, perhaps 25A.
Achmed99, some good points also...I would like to design it for a 20A branch circuit, and perhaps have a variant for a 15A branch circuit (or, a switch on the back to select). Regarding PFC, you are correct, this switch-mode converter will require active PFC (PF ~ 0.97) to be able to achieve the 25A.
« Last Edit: October 29, 2013, 03:10:27 pm by Centmo »
Offline Crazy Ape
« Reply #17 on: October 29, 2013, 04:02:34 pm »
Parts of quote reposted in red italics.
What happens in the event the the remote MCU connection is broken (or MCU failure)?
What happens if all but one cell is in bypass and the remaining cell has only partial charge. The user of device could stop charging at any time, particularly if it's taking time and they are in a hurry. A low cell in a series configuration is very bad in high current situations, it will run down first, and then start charging in reverse polarity. You don't want this.
« Reply #18 on: October 29, 2013, 04:26:48 pm »
Good questions Crazy Ape - I have also thought about this. In the event that the connection between the MCU and charger is broken, the MCU will be able to identify the problem, since it will be able to see the cell voltages and will also be measuring charge current (it has a current sense circuit). If some cells are in bypass, and the charge current is above that which the dissipating resistors can handle (power supply is not dropping output voltage as instructed), it is able to dump the power into its connected load.  I won't get into the specifics, but suffice it to say that it has a connected load which can eat this current safely, and an alarm will be activated to notify the user.
If the user stops the charging process prematurely, leaving one cell at a lower voltage than the others, the system will recognize this and signal an alarm to the user about a battery imbalance. The MCU can decide to discharge the higher-voltage cells to balance the pack, or demand that the pack be fully charged before allowing operation of the load. (The user cannot operate the load without the MCU's approval)
I have been looking for power supplies, and have found many 1U rack-mount units that can supply 0-60V, 25-28A: Eltek, Genesys GEN60-25, Kepco KLN 60-25, Sorensen XG60-28, Amrel SPS60-27. Unfortunately the quotes are coming back in the $2000-$3000 range. I think it's because these are designed for sensitive electronics, so are specially designed for low output ripple? Battery charging I would expect, could handle a noisier supply.
Anyone have any ideas for something a little more....affordable?
Offline Crazy Ape
« Reply #19 on: October 29, 2013, 04:49:20 pm »
There are things like this, but you'd still need to find a source of DC, and who knows if it's specifications are accurate.
http://www.aliexpress.com/item/Free-Shipping-1pc-ZXY6020-CNC-constant-voltage-constant-current-power-supply-module-60V-20A-1200W-high/1222064373.html
Offline Ericho
« Reply #20 on: October 29, 2013, 05:07:06 pm »
Itech may have somthing in their range
http://www.itech.sh/en/products.jsp?sortid=002
should be below $1000 at least
Offline NiHaoMike
    • Facebook Page
« Reply #21 on: October 29, 2013, 05:17:44 pm »
http://enginer.us/technologies/
Not sure how much the charger is by itself, might be worth calling them.
« Reply #22 on: October 29, 2013, 05:29:11 pm »
Thanks for the suggestions.
Ericho, unfortunately, it looks like iTech only has a 1200W unit (60V, 20A), or a 3000W unit. I will see how much the 1200W unit is though.
NiHaoMike, it looks like their system is based on Li-Ion only (not LiPo), and will not achieve 60V charging unfortunately. But, it may be worth contacting them to see if they're interested in sharing how they built their charger.
Crazy Ape, I have found that product during my search as well. It is interesting, and worth considering, even if it is only 20A. I will have to look for more details on it.
« Last Edit: October 29, 2013, 05:34:01 pm by Centmo »
Offline AmmoJammo
« Reply #23 on: October 29, 2013, 06:47:59 pm »
Can't say I've ever seen a Lithium Polymer powered cordless tool... those things catch on fire if you poke them with a stick  :scared:
I do like how this thread only gets half the details included until people see an issue with the original idea  :palm:
Offline Neilm
« Reply #24 on: October 29, 2013, 07:16:55 pm »
A commercial design will have to pass the the relevant safety standards. This includes requirements for protection circuits in the pack. Also, with a pack this large you might run into limits with the hazardous cargoes legislation.
I have seen block diagrams of large battery packs, but they tend to be from chip manufacturers who are selling solutions to it - for example TI have a very large range of chips that are designed to work with each other to do cell balancing, charge regulation, cell temperature monitoring etc. They tend to be solution in chips that are then tested and passed as "safety critical" components. They contain separate circuitry that acts as watch dogs to attempt to ensure it fails safe. Quite often they will use use serial communication (SMbus) to communicate between the battery pack and the charger to regulate charging. It also could go to a micro to allow charge monitoring.
You would then have to produce (or purchase) a 60V 2kW or so mains PSU to power your charger circuit.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
