I looked further into the ZXY6020, which Crazy Ape suggested. Turns out that its a buck converter, so in order to get 60V out, I would have to supply at least 60+V in. The DC input voltage range is 13-62VDC. So, I assume that you would need a 62VDC, 25A supply in order to run this thing at 60V, 20A. Good luck finding that.
So, I'm basically back to square one, staring down a $2000 telecom-grade 1.5kW DC supply. (still need to find a price on the 20A iTech unit).
NiHaoMike may be on the right track....I need to see how the EV guys are doing it.
