Regarding cell balancing, the cell balancing is being taken care of by a separate board, at the battery itself. Each individual cell voltage is being monitored to a 1mV accuracy by an AFE and MCU. As with any lithium charger, when any one cell gets close to 4.200V, charging will change from constant-current mode to constant-voltage mode so as to avoid an over-voltage condition (MCU will control charger remotely). When the highest voltage cell actually reaches 4.200V, it will be bypassed with a FET and power dissipating resistor in series. The FET will be switched on/off with some hysteresis to maintain 4.200V across the cell, until the rest of the cells catch up. This stage of the charging process is rather slow, compared to the constant-current charging stage, which will pump out the full 30A.
AG6QR, you brought up a good point that UL dictates I cannot exceed 80% of the branch circuit rating. 120V*20A*0.8 = 1920W. Assuming 90% efficiency, 1920W * 0.9 = 1728W. 1728W/60V = 28.8A. So, I may need to relax my 30A requirement to, perhaps 25A.
Achmed99, some good points also...I would like to design it for a 20A branch circuit, and perhaps have a variant for a 15A branch circuit (or, a switch on the back to select). Regarding PFC, you are correct, this switch-mode converter will require active PFC (PF ~ 0.97) to be able to achieve the 25A.
