I have a power supply based on the LM regulator series, when the power supply is turned off, it takes long time to discharge.
I have a voltage panel meter connected to it, and don't like the fact that the LCD will go off after some (long) time after shutting down the unit.
So is there a technique to automatically discharge faster the power supply when turned off ?
Something I can add to the power supply output (without modifying the existing PS), but of course the idea is that when the PS is on this circuit will present a small load to the PS.
Please comment or suggest.
