Author Topic: Earthing protection stainless steel Vs Zinc Plate?  (Read 8000 times)
Online Ian.M
Re: Earthing protection stainless steel Vs Zinc Plate?
« Reply #25 on: March 08, 2017, 03:36:57 pm »
Would I plug it in as-is  for my own use? Yes, after a basic HiPot test between the primary and the secondary.  I might add an external earth strap using a ring terminal secured under the case screw nearest to the power lead, if I wanted to keep it original but be able to earth the chassis.
Would I let anyone else use it as-is or leave it set up unsupervised in a family household? Hell NO.  I've already listed the stuff to bring it inline with current safety standards.
There's also the issue that its 120V  - off a miswired autotransformer it could be extremely hazardous.   Off a 55-0-55 portable power tool isolating transformer, it would be totally safe as-is.  Maybe the answer is to just put a 110V 16A fused industrial plug on it with a 3A fuse in the plug, so it can only be plugged into suitable isolating transformers?
Offline Siwastaja
« Reply #26 on: March 08, 2017, 04:05:40 pm »
Replacing the transformer would be very easy, too. I bet it's not too exotic of voltage, easily available with modern safety specs.
