Hi everyone,
i have an old device with separate power supply which i would like to replace since it does look very worn down and humms.
Since i dont have a datasheet, is there a way to know the max amp rating so that i can find an fitting replacement?
I measured +/- 12 volts at the outputs with multiple +12v and ground connections. Is it safe to assume they are the same?
Further more, there seems to be a floating pin connected to the frame.
Are there any other things that i should look out for?
Thanks in advance.
