Sorry,
this is a bad power supply for many reasons:
- The cooler for the diodes is probably not large enough to cool the rectifier diodes properly. If you have 1V or forward voltage (only vor very large Schottky diodes)
and 20A RMS, you have 40W on this small piece of metal - much too small.
- the arrangement of the 2N3055 pass transistors is thermally bad, because the space between the transistors is much too small.
Even with a large cooler, this will create a hotspot in the middle.
- The driver transistor gets hot as well, but is not cooled by a heatsink
- Load balancing is missing. Every transistor needs an emitter resistor, roughly so that at the maximum current leads to a drop of about half of the BE voltage.
- Crowbar for output protection is missing
My suggestion: AoE chapter 9, or some reference designs from the ARRL for ham radio power supplies (I think there is a good one from Bill Sabin, IIRC).
