Author Topic: High negative voltage (-100 to -500V) switching with minimal current  (Read 1746 times)
Offline SauliusTopic starter
  • Country: lt
  • Green green green green....
Hello
I am a final year bachelor in material science and i am quite a novice in electronics, but I have this project on my hands: for magnetron sputtering, on substrate we need to generate 10+ kHz switching 100-500v negative bias voltage ( we have wave generator and high voltage dc power supply, and we need middle part between these too), with minimal current, using only discrete components (i live in a small country and it would take a lot of time to obtain some intricate parts, and time is of essence here).
Thank You
PS, sorry for broken grammar
Offline qwaarjet
  • Use your imagination and pretend its linear.
Re: High negative voltage (-100 to -500V) switching with minimal current
« Reply #1 on: January 14, 2015, 08:11:28 am »
There are many MOSFETs capable of handling that voltage and frequency. However you will need a proper gate driver. For low frequency I use optical drivers but at this frequency I would look at a transformer based system like this.
http://www.st.com/web/en/resource/technical/document/application_note/CD00003897.pdf
Offline VK5RC
« Reply #2 on: January 14, 2015, 08:50:09 am »
Sorry to take things back in time but have you thought about a valve (thermionic)?
Offline fcb
    • Electron Plus
« Reply #3 on: January 14, 2015, 09:34:22 am »
I would probably use a small ferrite cored transformer.
Drive it (transformer) with a square wave (probably drive it with an H-bridge made from junk-box transistors or MOSFET's), vary the DC supply to the H-bridge (say 10-50V) to get your 100-500V. Don't use a gapped core - you are using the transformer as a transformer, not a flyback transformer.
Obviously use a fast rectifier diode to give you negative only pulses, probably load the secondary with a suitable resistor (this will reduce the ringing).
Offline 3roomlab
« Reply #4 on: January 14, 2015, 09:43:50 am »
photoflash style flyback -ve autotransformer?
