Hello,
I have an RF remote control toggle switch that has momentary latched and toggle abilities. I simply wanted to be able to turn on this very small LED light while I’m holding down the button. I’ve looked at the diagram of wiring and I can’t figure it out. Here is the picture of all the components I have what am I missing how am I not getting this. Because I’ve tried to connect it the way the wiring diagram shows and I can’t get the receiver to be the thing that turns on th light.
The light works, the battery is working. The RF receiver works, and the transmitter.
I just can’t get it wired right so that when I press the toggle switch and hold it down or anytime for that matter I can’t get the LED light to light up I’m sure it’s pretty simple thanks for the help the attachments show the wiring diagram they give for it and I’ve tried them but I can’t get them to work so I’m missing something one of them is for receiver and load use the same power supply Which is what I want.
