Author Topic: Powering HDMI Audio Extractors vs HDMI-VGA-Audio Converters  (Read 482 times)
Offline KorayTopic starter
  • Country: tr
Hi all,
I have a Google Chromecast device with a single HDMI output which I want to use with a HDMI projector. Unfortunately the projector has no audio output and I have no way to get sound out of such system.
When I search for in-line HDMI Audio Extractors I only find tiny USB powered items at around 10USD range, but when I search for HDMI-VGA Converters (with audio output) I find self powered in-line adapters for about 2USD price range. Price is not important, but I don't want to complicate the setup with an extra power cable for the audio extractor.
Here are some questions:
  • What is the difference?
  • Why can't they build cheap and simple audio extractors without audio output?
  • Can I re-purpose an audio capable in-line HDMI-VGA converter to HDMI audio extractor?
I am attaching two sample devices for reference.
K.
987974-0
987978-1
« Last Edit: May 10, 2020, 08:18:21 am by Koray »
Online NiHaoMike
    • Facebook Page
Re: Powering HDMI Audio Extractors vs HDMI-VGA-Audio Converters
« Reply #1 on: May 10, 2020, 12:52:00 pm »
Have you considered opening up the projector and rewiring the speaker output to external speakers?
  • Country: tr
« Reply #2 on: May 10, 2020, 03:51:49 pm »
The projector has no audio. I wouldn't do that anyway, I can just use a powered audio extractor.
But I wonder if the HDMI VGA cable can be converted into a HDMI bypass with audio output?
K.
Online NiHaoMike
    • Facebook Page
« Reply #3 on: May 10, 2020, 06:23:23 pm »
Not easily. HDMI operates well into the GHz and the only proper way to split it is to use active circuits. You might manage to get away with a parallel connection for such a short distance, but HDMI is fine pitch enough that I wouldn't consider it trivial to solder.
