Author Topic: powering up motor of a B&O stand with wireless relay module  (Read 386 times)
Offline nickvickTopic starter
Hello Guys,
First of all thanks for accepting me. Im a begginer of the electronics world.
I have a question regarding this project im doing which is above my league of knowledge.
I have an old B/O motorized stand and i wanted it to power it up with the (pictured) wirless relay board.
The old connection was a 4 pin connection pictured below, i cant find anywhere the schematics for the motor so I can't even understand which type of motor it is.
It has 4 wires coming out of it, 3 wires were connected to the pins (white, brown and yellow) while the 4th oddly (green)wasnt connected to any pin.
Anyways i rewired them with longer wires to make the job easier.
As far to my understanding, yellow and brown should be the wires that move the motor left and right, white should be neutral and green should be ground.
Can any of you give me any advice on how to wire everything on the eletric boards with relays? and of course if this is possible this way and if i need something more than that.
Thank you
