What is practically smallest SMD size, for making PCB and component assembly, for 1 to 100 pieces by PCBWay etc. for these components:
Resistor (signal, no heat rating required)
Power line by pass capacitor
LED as visual indicators, charging and done
Do they x-ray inspect board with leadless chips, 1 x 1 mm and 2 x 2 mm, and masking sure there is no assembly error, no solder or shorted solder? They need to be correct as it is too small for me to debug or re-solder.
Many thanks
