Author Topic: [ASK] About old Sanyo OSCON polymer caps  (Read 3331 times)
Offline BravoVTopic starter
  • +++ ATH1
« on: October 23, 2015, 06:59:59 am »
Bought bunch of these at local store, as they're industrial excess stock. Even I don't need them now, its just the price was so damn cheap, just < $5 for this 50 pcs of purple caps.  :P
Measured capacitance are spot on with LCR meter, with ESR at 0.045 Ohm (45 mOhm) @100KHz.
Size is 5mm tall and 10 mm diameter.
Questions :
1. Which type of OSCON is it ? For sure its rated at 105 C as printed, but I can't spot the type.
2. As these are old model, looking at the packaging style, do they rot over time ?
Attached cap's photo below.
« Last Edit: October 24, 2015, 12:40:32 pm by BravoV »
Re: [ASK] About old Sanyo OSCON polymer caps
« Reply #1 on: October 24, 2015, 02:31:05 pm »
Haven't heard of these degrading with time, and they are used a lot in older server boards, so must be a reliable unit.
Offline Pjotr
« Reply #2 on: October 24, 2015, 03:41:22 pm »
The only point is that they have silver plated wires. Over time they become unsoldarable due to oxidation/sulphurization. You can overcome this by scraping the wires blank again with a scalpel or something.
  • +++ ATH1
« Reply #3 on: October 24, 2015, 07:08:27 pm »
Thanks, noted.  :-+
Wonder why they had to use silver, is that common ? ::)
« Last Edit: October 24, 2015, 07:11:37 pm by BravoV »
Offline DanielS
« Reply #4 on: October 24, 2015, 08:36:44 pm »
The main reason is most likely solderability: clean silver plating wets very easily with most solder alloys.
  • +++ ATH1
« Reply #5 on: October 26, 2015, 04:32:04 am »
Whats wrong with tin plating as normal/common lower priced electrolytic cap, does silver is much-much better ?
But yeah, you watch the above photo carefully, I did scraped the pins with sandpaper as they're sort of dull/powdery white looking.
I guess these are > 10 or 20 years old aren't they ?
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #6 on: October 26, 2015, 04:34:36 am »
Never see these fail, they are solid electrolyte, like modern low-esr caps.
I have them high ranked in my "good stuff" list.
And due to environmental issues production of these caps are long gone, unless I miss something. Just so you know before you fit them into your xxxx pieces design (cap sizes/pitch is not same as most other electrolytic caps).
P.S. woa, 1000th post  :o
  • +++ ATH1
« Reply #7 on: October 26, 2015, 05:11:26 am »
What production environmental issues ?  ??? Mind elaborate more ?
Btw, congratz on your #1000 post.  :clap:
Offline Psi
« Reply #8 on: October 26, 2015, 08:11:45 am »
Yep Sanyo OSCON caps are A class.
