Author Topic: Calculating speed-torque curve for stepper motor  (Read 2945 times)
Offline EmilTopic starter
  • Country: no
    • ZeptoBit
« on: April 30, 2015, 11:43:41 am »
I'm making a spreadsheet to estimate speed-torque curves for stepper motors when used with a current limiting driver.
I got the formulas from the spreadsheet in this post: http://www.mycncuk.com/threads/1524-What-size-stepper-motor-do-I-need
Corner speed = 191 * Supply voltage / (Rated current * Winding inductance)
Torque below corner speed = (Holding toque * Set phase current / (sqrt(2) * Winding inductance) ) - Detent torque
Torque above corner speed = ( (Torque below corner speed * Corner speed) / Speed ) - Detent torque
Are these formulas correct / reasonable approximations?
I'm particuarly uncertain about the corner speed formula, because I don't know where 191 comes from and the calculated corner speed is higher than what I get from speed-torque curves from stepper manufacturers.
Coil resistance is also ignored, this seems reasonable as long as the driver is limiting the current, which I think will only be the case below corner speed?
Emil
