This is a funny thread because everyone seems to have a completely different idea how to do this "easily", and the ideas of others are seemingly unsuitable.
Of course you can MacGyver this up with almost anything you have lying around, but that's completely up to what OP happens to have.
I stand by my idea that boost converter is the simplest with easiest-to-understand schematic and working principle, with guaranteed zero need for building custom transformer(s) or inductor(s). Yes, you need to minimize the switching loop area, but OTOH, you don't need to think about transformer leakage inductance, minimizing it with proper winding patterns, obtaining litz wire, and adding snubbers nevertheless.
In other words: if all the hardships of boost described in this thread prevent OP from succeeding, I'm 100% sure any transformer-based topology will definitely fail, they have inherently more things to go wrong (also more potential to learn).
Transformer based circuit which needs the MOSFET Vds(max) to be theoretically rated "just" 2x input (not accounting for any parasitics) does not sound, IMHO, very appealing at all compared to simple boost which needs to be rated 3x input.
Same with flyback for example, the output voltage is reflected back to the input by the turns ratio making high conversion rates appealing, but if the conversion rate is just 1:3, the difference is small, and the new added parasitics may make it actually worse unless you really know how to build (and snub) it properly.
By all means go for transformer-based topology if you want to learn about designing and building them, but if the aim is to make a simple, easy to design, easy to build, low-cost and efficient converter, 1:3 boost is hard to beat. That's exactly why I changed a transformer-based 1:7 topology to a boost-based 1:3.5 topology when I had the chance to halve the output voltage requirement, and oh boy did it get so much simpler to design and build.
And I'm sure many will disagree.
And yes, 1:3.5 boost is getting close to the edge of the "makes sense" boost sweet spot but 1:3 is clearly within the sane area.
